I try to export mine timeline with frameserving so i can do the enconding with tempgenc. My first try is to do it with avisynth but temgenc can't read that format.
What is the best method to do the job??
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I am asuming that you have copied the plugin to the premiere plugin folder and installed the avisynth files to windows. Have you changed your priority settings in Tempge to all 0 or higher? When you export your timeline to tempge, adobe will create a file called c:\part.avi (i think) Use this as your input file for tempge. Start the frameserver before trying to load the file. Good luck!
frameserving dvd to premiere to avoid demuxing, is it possible?
By codemaster in forum EditingReplies: 3Last Post: 7th Jan 2011, 16:11 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 20:57 -
problem with tempgenc plus
By lancerx in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2007, 02:35 -
frameserving movie from premiere pro cs3 to avisynth
By colin66 in forum Newbie / General discussionsReplies: 10Last Post: 29th Oct 2007, 08:47 -
Frameserving with Adobe Premiere to Procoder?
By Soulman in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2007, 07:01
