Hello,
I am new to creating VCD's, and would like to record some old TV shows that I like onto them.
I'm using Ulead VideoStudio 5.0 to capture the video from my DV camera and create the MPG file, but the quality is really bad when I play the VCD on my TV. Very blocky looking.
Could I get some recommendations from people on a good DV capture or convertor that can give you VHS tape quality VCD's? Rendering time is not an issue.
Thanks,
Tim
What do used you play the VCD ?
If you are using computer or a SVCD capable DVD player, then you might want to consider compress to mpeg2. Ulead is normally pretty good, your video source may have too much noise that can upset a lot of mpeg1 conversion program. -
I'm using an Apex 500W standalone DVD player. Plays just about everything, and was really nicely priced!
For creating VCD's, I think it's pretty picky as to the exact format of the MPG though. I was curious as to whether or not other packages besides VideoStudio5 were better at rendering the images to be less blocky at full TV size.
Nothing can beat a free-bie, especially it it free.
Go get TMPGenc beta 12.
Quality can be directly tie to your video source. If you want great quality, you have to rip DVD and capture Hi-8 to
SVCD. -
i agree with sing sing. tmpeg is a great program that rivals some of the very expensive ones in quality. a little slow, but bearable. very adjustable. try it. you'll like it.
good luck
chas
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 18:49 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 01:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 13:13 -
Bad sound quality from avi's to DVD w/both Toast or XiliSoft DVD Creator?
By NoMoPackers in forum MacReplies: 7Last Post: 2nd Apr 2009, 03:57
