  1. hey, i burned a svcd and tried playing it in wmp (with mpeg2 codecs, etc) and powerdvd. in wmp, it doesn't recognize the file and therefore does not play. in powerdvd, i can see the movie, but there is no sound. i have ac3 stuff installed, but i doubt that is "interfering." any other ideas?
  2. Member wulf109's Avatar
    Jul 2002
    SVCD does not support ac3 audio,no player will play ac3 sound from an SVCD.
  3. that's not really my point. i don't think the ac3 sound it the problem. i mentioned the ac3 stuff to let you know that i have those codecs installed. anyhow, the sound works with windvd, but not powerdvd. any other thoughts?
  4. Member Conquest10's Avatar
    Chicago, IL
    if ac3 isn't the problem, why did you bring it up?
  5. because i don't know what the problem is, and i was just trying to give you some context about my problem (an earlier poster had problems with divx/xvid sound, which turned out to be an ac3 problem, so i am clarifying that this isn't the problem).
