Hey,
I'm having trouble with some avi's. The seek time (fast-forward or rewind) are slow/annoying as they take like 5 secs before it starts playing again. I heard that you have to manual insert more keyframes, but what is the best way? I tried virtualduab but you have to recompress and takes forever! Any tips? Thx!
Sys:
PIII-866mhz
512mb
32mb video card
XP pro
You either
-need a faster machine with more cpu power to seek faster
or
-have to insert keyframes, yes, you have to recompress, loose some quality and yes, that means lots of time too. -
When opening file with virtualdub open using popup extended open options, and then use rederive keyframe flags, then save the file with direct stream copy ticked for both sound and video, new avi will have the extra keyframes without the recompressing process, much quicker, however for a large movie file be prepared for the rederive process when opening the avi to take 1/2 an hour............
mkv to avi with xvid4psp! It's killing me! Help pls!
By Ramazan in forum Video ConversionReplies: 1Last Post: 28th Sep 2011, 07:52 -
Pls Help convert my 3gp file to mpg or avi
By Nanflexal in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 15:58 -
pls or m3u to avi
By py52126 in forum Video ConversionReplies: 1Last Post: 20th Jan 2009, 14:35 -
mkv to avi , help pls
By a_n00b in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 04:17 -
How to make a sample of an AVI file pls?
By incrediblej in forum EditingReplies: 5Last Post: 20th Dec 2007, 07:59
