Hi...
I have a question about DVD aspect Ratios.
Do all DVD's that have the same aspect ratio have the same amount of black bars on the top and bottom? Like if I looked at 2 different DVD's that said they were in 2:35:1 format, would that mean that both DVD's would have the same amount of black on the top and bottom of my tv screen?
Or for another example....I just bought the widescreen edition DVD of Spiderman. It says it is 1:85:1, and it has about an inch of black bars on the top and bottom of my tv. If I saw another DVD that was 1:85:1, would that mean it would have about an inch of black bars on my screen, just like Spiderman?
Thanks for any help, I'm just a bit curious.
Thanks so much!
Yes and yes
1.85:1 is the actual size ratio of the movie. so if another movie is also 1.85:1 it should be the same exact size on your screen.
Handbrake - ripping a DVD with various aspect ratios
By Ygramul in forum DVD RippingReplies: 1Last Post: 11th Aug 2011, 08:33 -
MPEG-1 on DVD with different aspect ratios
By DRP in forum Authoring (DVD)Replies: 8Last Post: 15th Aug 2010, 02:16 -
iMovie and aspect ratios
By sphinx99 in forum MacReplies: 3Last Post: 10th Mar 2010, 23:18 -
multiple aspect ratios on one DVD?
By towtruck in forum Authoring (DVD)Replies: 11Last Post: 7th Jul 2008, 02:58 -
Aspect Ratios
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 15:13
