Hi,
I am having trouble encoding a file to VCD
Audio
192kbps
Video
23 Frames a sec
146kbps
sample size 24 bit
Xvid compression
When I go to encode it with TMPGEnc it won't just let me use that file for audio. won't even let me in just gives me an error. So I try and go and encode it with Virtual dub. It won't save it to .wav I just get an error saying the file compression isn't compatible with the file input. ?????
So I try it with aviwave and it encodes but It is only 134 mb and TMPGEnc says it isn't long enough ( duh it should be about 800mb)
I have done everything the guide from here has told me to do. But I can't get an audio file in there to encode.
what do I do?
It sounds like AC3 for sound. Look at this and maybe this or frameserving.
Regards.
Trouble re-encoding AVI (XviD)
By Puppybarf in forum Video ConversionReplies: 5Last Post: 18th Jan 2011, 19:20 -
Encoding Blu-ray to Mp4 with RipBot Trouble
By F.Garvin in forum Blu-ray RippingReplies: 2Last Post: 2nd Nov 2010, 23:30 -
Trouble with mp4 file
By garybeck in forum Video ConversionReplies: 1Last Post: 11th Mar 2010, 13:38 -
Trouble editing a .sub file
By VidHunter in forum MacReplies: 4Last Post: 15th May 2009, 12:02 -
Having trouble capturing an .swf file...
By Captain Satellite in forum Newbie / General discussionsReplies: 3Last Post: 9th Aug 2007, 07:54
