I have a standalone Pioneer DVR-7000 which I have used to "master" my discs.
I am now wanting to add menus and chapter stops and such via the computer as it can't be done on this unit.
I was looking at something like the Pinnacle DV500 DVD & DVDit! for possibly doing the work?
Questions :
I was going to play my master dvd-r disc from a dvd player into the computer - Is it possible to somehow capture the video to the HardDrive via your Computer System's own dvd player? Or do you have to capture from a completely seperate outside source, like via the s-output from your dvd player to the breakout box?
I was also either going to purchase a Pioneer internal drive to burn to, or either burn the completed work back out to the Pioneer DVR-7000.
Do you guys have any suggestions for this setup?
Any potential problems or situations I need to be aware of from the description above?
Video Quality is the most important factor, as I must be able to produce the highest quality video with no loss, and have the ability to tweak and adjust scenes and such. I want to end up with a high quality "master dvd-r" with menus and chapter stops for navigation.....ANY advice or suggestions? I am new to this as far as using the computer, but have been using the standalone Pioneer for sometime now, but need a way to get menus to the recorded discs. I should be able to capture screen grabs for menu pics and such from what I can tell about the setup???
THANKS !
Results 1 to 1 of 1
Creating menus: DVD Styler re-encoding question.......
By bahjan in forum Authoring (DVD)Replies: 3Last Post: 21st Dec 2011, 05:54 -
Creating DVD menus with DVDAuthor(linux)
By sumit_pankaj in forum Authoring (DVD)Replies: 1Last Post: 11th Jun 2009, 11:00 -
Creating a DVD with Menus and switchable subtitles on Mac OS X
By koke_broke in forum MacReplies: 7Last Post: 27th Mar 2009, 12:43 -
Creating DVD Menus
By JARRE2000 in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2009, 15:08 -
editing DVD (vob) clips and creating a new DVD with menus
By gappman in forum Newbie / General discussionsReplies: 1Last Post: 5th Sep 2008, 08:30
