How do I enable and disable DMA in XP?
My Sony DRU-500a says I have to disable this to install the latest firmware.
Thanks!
-Alex
Results 1 to 16 of 16
let me think...
Device Manager
IDE ATA/ATAPI controllers (choose prim. or sec. based on wher it is)
Advanced Settings
Theeere you go. You should see it by now. -
Originally Posted by donpedro
By the way.... it's funny but microsoft have support web page too
http://www.microsoft.com/hwdev/tech/storage/ide-dma.asp -
You probably have to be logged as administrator (XP Pro) or owner (XP Home) to see that page. Also, make sure you are doing the properties on the Primary IDE or Secondary IDE Channel (not IDE ATA/ATAPI controllers) as donpedro mentioned.
2. Expanding IDE ATA/ATAPI controllers
3. Right clicking on Secondary IDE Channel
4. Properties
5. I see the following tabs: General, Driver, Resources
No Advanced tab.... !?
-Alex -
I was just trying to save some space here...
I thought that it is obvious... my bad...
But that Microsoft link is fine -
Originally Posted by mimo330ci
Try start PC in "Safe Mode". I am not sure but it is possible that it will be disabled by default and I think that if you start it in Safe Mode, you have to log in as Administrator. So as they say in my country "You will kill 2 flies with one shot".
I have realy fun with this one... Who could believe that my Win2000 help will have answer for this.
To change IDE controller settings
Open Device Manager.
Double-click IDE ATA/ATAPI controllers, right-click the IDE device for which you want to change advanced settings, and then click Properties.
On the Advanced Settings tab, make the desired changes.
Notes
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
To open Device Manager, click Start, point to Settings, click Control Panel, and then double-click System. Click the Hardware tab, and then click Device Manager.
The Advanced Settings tab may not appear for all IDE controller devices.
Some of the advanced settings for IDE controllers are device dependent. Read the device manufacturer's instruction manual to determine which settings you can change.
You will not be able to change the setting in Device Type if Windows 2000 has already detected an IDE device on an IDE channel. This prevents you from selecting None, which would disable the IDE device. If you want to disable the device, see Related Topics.
If you are not an administrator or a member of the Administrators group, you can use Run as to perform certain administrator functions. For more information on how to use Run as, see Related Topics -
Thanks guys!
-Alex -
Hello,
This was posted on the Intel website in regards to their application accelerator:
Automatic Selection of Highest DMA Transfer Mode
Intel Application Accelerator automatically enables the highest transfer mode supported by the ATA/ATAPI device and Intel chipset. For example, a CD-RW drive that supports a maximum of UDMA-2 will be set to this mode with no interaction required. Two devices that are on the same ATA channel can even be using different transfer modes.
Is this better than enabling the DMA function?
How / where do i disable coreavc and enable ffdshow to handle H264
By timbre in forum Software PlayingReplies: 3Last Post: 11th Feb 2010, 07:29 -
Enable VCD LG BD370
By mairel in forum DVD & Blu-ray PlayersReplies: 6Last Post: 4th Nov 2009, 14:17 -
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 10:10 -
How To Enable PC To Read DVD-R
By Jjay in forum Authoring (DVD)Replies: 10Last Post: 5th Jan 2009, 16:47 -
Mass disable of XP Pro services, How to Re-enable all at once easily?
By TBoneit in forum ComputerReplies: 2Last Post: 16th May 2008, 14:19
