Hey everyone.
I'm trying to decode a movie and put it on SVCD using AVI2SVCD and CCE 2.50. Sometimes it work flawlessly, others I get this weird error that pops up out of nowhere. I used VirtualDub to check for errors in the avi but there are none. I'll decode it again and it'll either work fine or error again in a different spot.
Here's the error:
fexp_close() failed:*** Could not close the file <file name>*** The file is invalid.
[Windows error code: 0x6 6]
Any ideas? Thanks.
I have had the same problem, yet only when the original avi was encoded in divix 4. Have never had the problem with divix 5.xx. TMPGEnc seems to encode just fine, so whenever I have this problem, I use TMPGEnc and all is good. I would rather use cce 2.50 all the time, so I am curious what I need to do to not have this error.
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 10:45 -
VBR in CCE SP2 creates playback time error leading to no audio
By Albedo in forum Video ConversionReplies: 22Last Post: 11th Jun 2008, 15:23 -
CCE, MP4 and AviSynth Error
By Maikeru-sama in forum Video ConversionReplies: 28Last Post: 11th Jun 2008, 04:24 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 31st Jan 2008, 23:24 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 04:46
