i have everything i need.... i think. but, when i try to select the audio compression, its shaded so i can't select it... anyone know whats wrong with it...here's what i've doen so far..
Go to the file menu and click open file
2. Choose ur video file and press open. the program will now parse the movie , which in some cases takes as long as 10 minutes depending on ur processor. if this process fails for some reason u have something wrong with the mpeg. i know i hate it too , its happened too many times!
3. Go to the video menu and choose filters
4. click add and choose 0 transform
5. press ok
6. u will see a cropping button on ur bottom right corner. click it
7. mess with the numbers so that the grey shade covers all the unneccessary area that u want covered {like those pesky cinema style strips on the top and bottom of the screen}
8. press ok
9. click add again
10. choose resize
11. change the setting from nearest neighbour to precise bi-cubic.
11. exit the filters area by pressing ok.
12. go to video again and choose compression.
13. choose divx low motion codec.
14. click configure
15. set the keyframs to every 1 second and the crispness to 100 and the bitrate to anywhere between 360 and 900. i usually use 512. press ok twice.
now when i get to the audio part... i can't select compression... any help is greatly appreciated thanks in advance
