In my thing frame 7374.. .
Before I did then the image would pause in WMP until I seeked past it.
I used DIVFIX and it fixed it...now the bad frame looks slightly worse but it is okay and doesn't stop the picture
I was trying to seperate the Video in Virtual Dub, but it crshed on this error AFTER rebuilding the index.
How do I deal with this? Thanks
Note- I tried using 2 of Virtual Dub's methods
I opened the file, clicked on pop up extended options and selceted "re-derive keyframe flags" and it would error and crash once it read that bad frame... -
i find that tmpg is better for splitting... use the wizard and select souce range, slide the bar to the middle and there you go...
hope that helped -
magomago, this should help you with your bad frames:
http://www.vcdhelp.com/forum/userguides/117930.php
Hope That Helps!!!
:P :P
Is it possible to Fix Bad Reception Artefacts with AviSynth??
By VideoFanatic in forum RestorationReplies: 6Last Post: 15th Nov 2011, 16:31 -
Fix bad avi file
By TBoneit in forum Video ConversionReplies: 8Last Post: 4th Oct 2011, 12:17 -
MPEG-4 frame skip problem - any way to fix it?
By TMHKR in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 08:42 -
The timing between movie and subtitle is bad. can I fix that?
By Codonauta in forum SubtitleReplies: 4Last Post: 28th Dec 2009, 14:39 -
how to fix: MKV to MP4 with bad ac3?
By cjh1452000 in forum Video ConversionReplies: 2Last Post: 28th May 2008, 04:11
