Well, I can say that I think KaiCherry is on the right track (overall)... I would love to see the software have DivX input support for SVCD/CVD though... or I can just stick to ffmpegX and tinker with the denoiser values until my anime fansubs come out just right.
I know that the tools being used on OS X from the Unix community work right, but we are 'mis-using' them like Kai stated.
One tip I can give to those doing DivX->VCD/SVCD/DVD using ffmpegX currently...
- The 3:2 pulldown of most NTSC clips causes havoc on how one is supposed to configure mpeg2enc, and great care must be taken. I have found that you don't need to manually set the pulldown, and setting the pulldown causes out-of-sync encodes. However, if you have a 23.97 fps (NTSC Film) clip in DivX or .mov, simply DON'T TOUCH the pulldown settings, and leave the output framerate at 29.97 fps. mpeg2enc will set the pulldown flag and ensure everything is set properly.
Results 151 to 180 of 200
Slaughtering the competition with amatuer-quality VCD authoring abilities... fear my non-l33t skillz.
again thanks to everyone for the encouraging and kind words.. and i hate to come off sounding like a jerk here, but please dont make me answer this again..the input to the program is from DVD ONLY and that will NOT change.Originally Posted by Krevinek
there will be no vob input, no mpg input no divx input no mov no dv -- and that is the way it is.As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind. -
When you folks mentioned that MPEG2 encoding would be slow, how slow are we looking at?
So lets say, a 1h 20m movie... approx. how long does the encoding take on your machine?
and what machine is it your testing on?
Thanks... -
i actually have yet to do extensive benchmarking so its difficult to say. One thing is certain - the superdrive slows down the process because it isnt that fast of a dvd reader. I'm workin on a DP 800 with 768 megs of ram, ill give some times when i acurately have them figured out. But i will say one thing, it will be pretty painfully slow for anyone on an old g3 or g4.
Well, painfully slow is better than nothing no?
I'm running a Dual G4 1GHz, with 512DDR so I'm thinking I'll be alright.
Granted the Pioneer DVD-RW (Superdrive) that's in here will be slow on the ripping process, bah.. no big deal... I get slow ripping as is... a little slower won't bother me. -
An update...
first off, if I talked to you online yesterday, you need to find me today to get a build to test
Ok folks...there have been some core changes to improve the speed.
First off, all of the output and processing goes thru the term. The status display gui stuff was just really killing the speed to the point of diminishing returns. it looked really slick, but it had to go.
No, its not a cut/paste thing, so this doesn't get you tweakable options...sorry
Also the terminal stuff is highly threaded, so different code is being composed to allow the users to "bail out" gracefully.
Oh yeah...the app is called "forty-two"
Anyone that is testing it will be posting comments, etc as they run thru it and get results, etc.
I haven't checked any of my pm's yet...please excuse that. Having to rewrite a chunk of this today sorta cut into my time
-K -
Actually, since it is going through the terminal, you can just abort the process once it starts in the terminal, hit the up arrow key to show the command that was entered, modify it, and then hit enter. This is exactly what I needed, and I'm happy it turned out this way. Also, in case of error, this allows you to debug the problem, and hopefully fix it.Originally Posted by KaiCherry
===>Kai and Bile: OK, I understand that there will be no other source options besides from DVD disc, but how hard would it really be to run the commands on a VIDEO_TS folder on a HD instead, since it is in the same format as a DVD? This would greatly improve the reading speed, and make up for the superdrive's read speed shortcomings. If this is not possible, I guess I'll just have to make an unencrypted disk image of a DVD on my HD, mount it, and use that as a source. DeCSS is unnecessary using this procedure. If there's a will... -
[quote="WiseWeasel"]
erm... actually...noOriginally Posted by KaiCherry
Its not like you are used to.
I'll look into it, but i do'nt think thats a-gonna work on General Principle because I'm taking to a *device* and not a mount point.===>Kai and Bile: OK, I understand that there will be no other source options besides from DVD disc, but how hard would it really be to run the commands on a VIDEO_TS folder on a HD instead, since it is in the same format as a DVD? This would greatly improve the reading speed, and make up for the superdrive's read speed shortcomings. If this is not possible, I guess I'll just have to make an unencrypted disk image of a DVD on my HD, mount it, and use that as a source. DeCSS is unnecessary using this procedure. If there's a will...
-K -
You need to im me Wise...I have somethimg for you.
forty-two !=other "GUI Wrappers"... 'kay?
-K -
K, did you receive that? If not, feel free to email or AIM me.
You might like this... Possibly?
If you do, and would like to use it, I'll send you the PSD file so you can convert it to any format you might like.
Possibly even make the ICON out of it.
*shrug*
Just a thought... -
nice!
Actually, if you haven't picked up on it, "42" is a Douglas Adams reference, and the icon looks a lot the avatar icon thingee attached to my message.
-K -
PRAISE (insert deity of choice here...)!!!!
HUGE strides were made with forty-two with regard to end-user simplicity and installability.
so much so, that everyone may be able to join us in testing as soon as tomorrow evening. We are running this thing thru the ringer again to day, and add "small touches" to make it just that much nicer.
if you got a test version from me yesterday, *please* contact me asap to get this morning's build.
thx,
Kai -
What does one have to do to get a test build?
- Elreeko
"I have not failed. I have simply discovered what does not work." - Thomas Edison -
Sacrifice an adult male goat on the thirteenth full moon of the year of the chicken, while chanting the words to 'karma chameleon' in a monotone voice over a repetitive drumbeat.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Originally Posted by WiseWeasel
is that all? man i was gonna do that anyways.. oh wait, i dont need a test build
Weasel:Originally Posted by WiseWeasel
I tried that and it didnt work... Any other suggestions? -
femaly goat? young male goat? sheep maybe? I dunno, keep trying and let me know when Forty-Two magically appears . . .
That' s all. Whew!! I thought it would be something difficult and annoying like maybe being forced to do all my graphics work on a PC for a month.
Talk about hell on Earth.
Keep up the good work.
Really looking forward to this app.
- Elreeko
new build...
fixes missing ac3 issue, more speed (est 15hrs dvd->dvd), fixed "divx stop"
You know where to go and who to talk to...
The rest of you guys... ~3days its looking like
The docs, readme's etc will be wrked on tonite since i don't think anything major is going to change before release at this point
OH!
We found a bad dvd, we think...Xmen "Special Edition"
If you have this dvd pm me.
-K -
WOOHOOO!!
The site is almost done.
My beta works.
Everyone...You will WORSHIP this program.
Q"Good Luck 007"
In Memory of Desmond Llewelyn -
This program is working great for dvd-9 -> dvd-5 encoding, including subtitles for those foreign flicks. Yes, you will soon be creaming in your cheese when you see how simple it has become. Hip Hip . . .
Kai,
I have a few questions for u:
A) Can you put a thing to type in your desired resolution.
Sometimes(for me) encoding at 512x288 gets HQ video, at minimal sizes.
B) Does 1 CD setting automatically calculate the bitrate for the movie?
Thanx
Q
P.S. the site is almost done, I have to get a few more graphics on.
Do you have the pic of the green guy?"Good Luck 007"
No. maybe next version.Originally Posted by qshartle
Sorta. 1CD Divx has become sort of, passe as in all honesty, they look like hellB) Does 1 CD setting automatically calculate the bitrate for the movie?
I didn't concentrate too much effort on them
mDVD setting and nDVD setting produce MUCH better results, *orders* of magnitude better, and should fit easily onto 2 CDs
-K -
That is so awesome. I'm looking forward to this.Originally Posted by WiseWeasel
will this also split a dvd 9 into 2 dvd 5's ? or can you take a dvd 9 and take things away to make a dvd 5 with it, like that ifo edit pc program?
thanks
i can't wait.
pants
Philips DVDR 3455H/37 has burner drive problems- SOLUTION-maybe
By Roberht in forum DVD & Blu-ray RecordersReplies: 8Last Post: 6th Jan 2015, 18:02 -
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 10:49 -
problems with sync
By joachimfreitag in forum MacReplies: 5Last Post: 10th Sep 2009, 16:00 -
Door/tray stuck problems.... solution?
By garybeck in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jul 2009, 17:09 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 21:42
