Hi,
I had a video on vhs and I dubbed it to Hi8 (yes i know that it won't make the quality any better.) Anyway I captured it through firewire so the file is an avi file. When I export the file back out through firewire it looks the same as when I imported it (Very Good) But when I make a dvd of it, it is a little blocky. I use Sonic DVDit, I have the Bitrate set at 8000kb/s, I let the program encode the video and audio for me. I burned it on a DVD-RW and seen that it was a little blocky. Then I used TMPG to encode it using a CBR of 8000kb/s then did the rest of the authoring in DVDit and came out with the same results. Anyone know what it could be?
Impossible to see the future is. The Dark Side clouds everything...
I want to make a DVD not SVCD. My file is an avi, it is 1.59gb (about 8 mins of video) when I encode it to dvd it is only around 500mb. Is this right?
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 04:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 21:15 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 17:04 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 21:51
