MY FRIEND JUST GOT A P3 1 GIG,AND I SHOWED HIM HOW TO RIP.AFTER 30 MIN IN DVD TO AVI,I FINALLY WAS READY TO ENCODE WITH TMPEG 12I.THE MOVIE WAS FIRST BLOOD,ITS ABOUT A HOUR AND A HALF LONG.USED STANDARD VCD TEMPLATE.TMPEG TOOK 10.5 HOURS TO ENCODE.MY ATHLON 1.4 TOOK 2.5 HRS,JUST AN EXAMPLE OF ATHLON SUPERIORITY OVER INTEL!!!
Hi!!
Have you any compatibility problem with AMD 1.4 Ghz??
I want to buy one.
Thanks. -
ACUALLY I HAVEN'T HAD ANY PROBLEMS AT ALL.I ALSO HAVE DAZZLE DVC 2,AND HAVEN'T HAD NOT ONE ISSUE.
HI!!
I´ve got a P3 550MHz and Tmpeg ver. 12i. I encoded Anti Thrust from DIVX to Svcd, using VBR 900 - 2500 Kbit/s, sound 192KHz and all the rest on maximum! The whole thing took about 9.5Hours!
U have a P3 1GHz and it took almost the same time, u must have serious problem with your system!
Although you´re testing AMD´s latest against an P3! You should test P4 insteed but i agree that AMD is a very strong competiter!!
/Ola Lindell
Intel Processors
By hardy in forum ComputerReplies: 6Last Post: 9th Jul 2011, 18:21 -
intel going for the knock out...
By deadrats in forum ComputerReplies: 0Last Post: 9th Dec 2009, 21:09 -
Intel Core 2 Duo T7500 2.20 vs. Intel Core 2 Duo E8400 3.0
By vatkat234 in forum ComputerReplies: 6Last Post: 27th May 2009, 11:42 -
Intel Q6600 Kentsfield or Intel E8400 Wolfdale??? Help me decide which one
By budz in forum ComputerReplies: 33Last Post: 12th Mar 2009, 01:19 -
Intel P4 overheating ?
By Illusionist in forum ComputerReplies: 9Last Post: 31st Jul 2008, 17:03
