Not sure if this is the right place to post this but here i go:
I don't really have a problem but 2 days ago i copied Murder By Numbers DVD for encoding to SVCD at 2cds. I used DVD2SVCD, captuered subs and all with help from a guide here on vcdhelp and this took really long time. It took me over 40 hours to complete this operationIs there a way to improve the speed? I didn't use the computer much during this procedure, mainly the computer stod here managing itself... The dvd was on my hard drive etc.
My system is:
P4 450
768mb ram
100gb wd harddrive
thanks in advance...
Hi,
40 hours on a pIII 450 is quite normal. I use a pIII 750 and it takes me 15-19 hours to convert a film.
You can cut in time bij changing the quality settings. If you use dvd2svcd with tmpgenc you can change the "rate control mode" or "motion search precision"
But i don't recommend it because you also are degrading the quality of your movie.
Greetinz.. Lennie -
A P4 450?...... (P4?)
Anyway... did you use Tmpgenc or CCE to encode, the reason im asking is that if you set CCE to encode with 3 or 4 passes, it can take a while even on my Athlon XP 1800+.
(P4 450?).... -
Only take 3-5 hours with CCE 2.5 SP for DVD Movie. Plus my computer not really fast but enough.
=-VNPN=-
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
