  1. Just d/l the WMP 9 for Windows Me.....when I play some mpegs...I only get audio then when I click on the blank screen I get the picture but a smaller size located towards the bottom left of the player...
    If anyone is experiencing the same problem or has a suggestion to correct this....please lemme know what to do..??
    THX !!!!!!! Happy 2oo3....!!!!!!!!
    Dec 2002
    That's WMP9 Beta, right? I have had WMP9 break things to the point that I had to re-install w2k.
    Which MPEG's isn't it playing? VCD? SVCD? DVD?
    Do other DVD players work? WinDVD or PowerDVD? Try installing one of them and see if you get your MPEG codecs back.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
