I try some DVD9 to DVD5 conversion with both
DVD2DVDR (http://users.pandora.be/DVD2DVD-R/)
and
DVD2SVCD(http://www.vcdhelp.com/forum/viewtopic.php?t=114252),
I use the same cce2.5 setting, 4pass, but the video quality of DVD2DVDR generated Movie is worse than DVD2SVCD, especally on fast moving
objects.
So far, right now every time I take DVD2SVCD's video result,and the
audio/subtitle/chapter data from DVD2DVDR, then author them again
with ifoedit to get my final movie.
Anyone got the same issue? any comment on it? or do I miss something? why do I use the some video sorce and same cce encoder(same setting), but get the difference video quality?
mpeg2002,
You must not be applying pulldown. Make sure on the encoder tab if you are doing NTSC FILM that the forcefilm flag is checked.
PS if you are going to be doing subtitles make sure "set drop-frame' is also checked.
Video quality issue!
By Sh@DY in forum Software PlayingReplies: 18Last Post: 23rd Aug 2011, 08:42 -
VIXIA HF100 video quality issue
By rruth in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 2nd Feb 2011, 22:13 -
TS to MKV using RipBot video quality issue
By dracusorr in forum Video ConversionReplies: 5Last Post: 14th Sep 2010, 07:28 -
By dracusorr in forum Newbie / General discussionsReplies: 1Last Post: 12th Sep 2010, 00:34 -
Video Quality Issue
By neumannu47 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 10th Feb 2008, 14:19
