  1. Member dawsonj's Avatar
    Sep 2000
    Manly,NSW,Australia
    Can you cut one CD that has a VCD compatible and an SVCD compatible MPG on it at the same time. For eg use "non stanrdard SVCD" in Nero and then use a mix of mpg1 and mpg2 sources.
  2. Member dawsonj's Avatar
    Sep 2000
    Manly,NSW,Australia
    So you can do it then, I didn't want to waste a blank CD.
    I assume saying "yes you can" means you can actually play it on a DVD player and not that Nero let you burn a useless CD )
  3. Yes, you can burn it...
    It's hard to say whether it will work properly though. It really would depend on your player. There is no reason why it "should" work as it is a non-standard SVCD.
    Regards.
    Michael Tam
    w: Morsels of Evidence
