I'm encoding replays of a racing game to svcd.(did I say that right?)
I get the replays from the game in .avi format at 30 fps. The sound is saved seperately as a .wav file. I use Ulead MovieStudio 6 SE DVD to put them together as an mpeg2 and burn a svcd. When I play it (it's only 5 minutes long), about 1.5 minutes into it the video will stop on a frame and the audio continues.
It does this on both my stand alone and pc.
Any thoughts?
Thanks,
87RedVette
Open the avi file in vdub and check for bad frames. Click on video, scan video stream for errors. Bad frames can cause a freeze in the video.
If there are bad frames save the file with a new name. It will be saved without the bad frames. -
Thanks for the reply.
I scanned for errors and recieved an error. AVIOuput: The parameter is incorrect.
As I said earlier, this avi file is a replay of a game. I don't understand how it could be corrupt.
Thanks for your help,
87RedVette
Play back stops and starts but audio is fine
By muay in forum Video ConversionReplies: 2Last Post: 22nd Apr 2011, 12:46 -
Video Stops Playing
By DJboutit in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2009, 02:54 -
Video freezes, audio continues in Nero
By lj01 in forum EditingReplies: 2Last Post: 7th Apr 2008, 10:58 -
audio stops way before end of converted movie and is out of sync
By jboyd in forum ffmpegX general discussionReplies: 11Last Post: 17th Dec 2007, 05:12 -
Flash Video Freezes But Sound Continues
By rocky6190 in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2007, 16:35
