Hi folks here, I am turning out tu you as experts here, I need an advice, please.
I created VideoCD (Aliens movie) in Nero 5 using its assistant from *.mpg file. It uses 2 CD's. When I put those CD's into DVD player, no problem with playing, it starts play movie correctly and fine. But problem appeares when I try pause CD or rewind it backward or forward, it doesn't work. But interesting thing is that second VCD is working properly, only first doesn'tI am sure I created them by exactly same way... My DVD player is Grundig GDV-130. Do you have idea what I could make wrong? I created them by 20xspeed.
Thank you
T.
Johny Becher. Friend of yours ;)
Well, I was investigating and found out this:
There is no problem with DVD Player definitely
Which is good. Real reason of the problem is, that some older Nero software didn't write the "scandata.dat" file into one of the folders on VCD. So I am going to check it this evening and will compare those CD which work fine with those which don't.
However, there should be a lot of this problem related topics (regarding VCD-130) on the interent, but I was not able to find out any. Do anybody know about it, please? Thank you.Johny Becher. Friend of yours ;)
what to do when a relatively new dvd recorder doesn't function correctly?
By xtube in forum Newbie / General discussionsReplies: 1Last Post: 17th Aug 2010, 05:02 -
DVD Doesnt Play Correctly On Stand-alone Player! (Skips)
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 16Last Post: 12th Sep 2008, 20:07 -
Panasonic DMRES45V DVD remote doesn't work correctly
By cep8719 in forum Newbie / General discussionsReplies: 2Last Post: 27th May 2008, 12:00 -
FLVtool2 doesn't install correctly
By chaosmoon in forum ffmpegX general discussionReplies: 5Last Post: 12th Feb 2008, 20:25 -
DVD player that will play Divx correctly.
By ThaDraGun in forum DVD & Blu-ray PlayersReplies: 6Last Post: 15th Oct 2007, 08:59
