  1. I have recently purchased a DVD player that will play VCD and SVCD. I burnt one VCD and viewd it, but the quality was terrible.
    Is there anywhere I can get an ISO or Bin/Cue of a VCD and SVCD of the best quality that I can try on my DVD player?
    R
  2. maybe you should try downloading an AVI on kazaa(look at the resolution, if its more than 400*500 its good quality) and convert it do an SVCD (you'll find info about how doing that on this site)
  3. I have done all of that. I have converted TV shows to VCD and some home movies.
    I am just trying to get an 'ideal' benchmark.
    Thanks for the reply.
  4. dont mention it
  5. Member MpegEncoder's Avatar
    Dec 2002
    Wish I was on Catalina Is
    Check the links on the left
