anyone know of a way to mux a mpeg2 (.m2a) audio file into a divx .avi file via the command line? im trying to convert a mpeg2 to divx via automation (command line batch commands). right now i am using avisynth > avs2avi but that only gives me the video i need to multiplex the audio into the .avi. i have tried using muxavi but for some reson when i try to mux a compressed mp3 it comes out as static. (if i use avimux's gui to compress my m2a file however it comes out fine, are there any command line options in muxavi to compress a audio file while muxing?)
Results 1 to 1 of 1
MPEG-2 transport stream... how to mux audio/video?
By Navstar in forum ffmpegX general discussionReplies: 1Last Post: 19th Feb 2010, 18:22 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 11:10 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27 -
Mux a DTS track to a MPEG2 TS file
By DrJonesIsBack in forum DVB / IPTVReplies: 7Last Post: 25th Nov 2007, 17:17 -
How is done the sync between audio and video in a MPEG2-VOB file stream
By rmanal in forum EditingReplies: 0Last Post: 22nd Aug 2007, 10:33
