burning vcd/scvd with chapters/menu etc...
It IS possible, is it not? I had an argument with someone about this, and i couldnt conclude from several articles/pictures that it WAS possible.. so is it? :) (i believe one of those articles was http://www.vcdhelp.com/dvdmoviefactory.htm ...
TiA
Results 1 to 9 of 9
_o\ \o\ \o/ immz \o/ /o/ /o_
it is possible, Nero will do it easely for you
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
the menu nero produces is not the best, do it with Ulead VideoStudio 6. I could do it with my VCD but my DVD Player got no number-area ( i'm german and don't know whats a "Zifferntastenfeld" in english is
)on the remote
The ones from Ulead are much better and nicer!!! -
VCD and SVCD chapters and menus are not chapters and menus like DVDs have - no arrow keys and hilighting, and you use the numeric keypad for everything. The entrypoints used for chaptering work a bit differently, too.
Originally Posted by immz0r
VCDEasy can author menu's and chapters. Here's a guide:
http://www.vcdhelp.com/forum/userguides/84327.php
Hope That Helps!!! :P :P :P -
Yes Ulead DVD Moviefactory will make great VCDs with menu but they are not true DVD menus as the two formats use different navigation buttons - the VCDs will use the number buttons (1-9).
VCDeasy is a great program also although you have a bigger learning curve but it is more powerful.Panasonic DMR-ES45VS, keep those discs a burnin' -
VCDs and SVCDs definitely support menus! As stated before, VCD and DVD menus are different so they don't support the same things.
For an idea of what VCDs and SVCDs support, have a look at: http://www.michaeltam.com
VCDEasy ( http://www.vcdeasy.org ) may not be the simplest program to use, but it is much more powerful than most of the commercial alternatives. Furthermore, it is free. Even more powerful than VCDEasy is manual authoring of the VCD with a text editor. This isn't for the faint-hearted but is very rewarding in what you can do.
For example, the Official VCDHelp.com PAL/NTSC Demo Video-CD was authored with the VCDImager system (i.e., the backend of VCDEasy) by manual authoring of the XML descripter file.
Regards.Michael Tam
w: Morsels of Evidence -
thnx a lot =)
trying to download vcdeasy but its overloaded i think :P_o\ \o\ \o/ immz \o/ /o/ /o_ -
You can also download VCDEasy at Doom9.org.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Newbie question: menu and chapters
By cheerful in forum Authoring (Blu-ray)Replies: 0Last Post: 19th Dec 2010, 23:17 -
Without Menu, but with Chapters...
By video_enthusiast07 in forum Authoring (DVD)Replies: 10Last Post: 13th Jul 2009, 09:22 -
Need more than 15 chapters on my menu
By Grunberg in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 07:17 -
DVD with no menu and just chapters
By marshyman in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2007, 17:36
