I am looking for short VOB files so I can make a test cd for different bitrates to check DVD players.
OOH...VERY HELPFULL ENGLISH MAN
SO THERE IS SOME THING USEFULL YOU CAN DO
YOUR STILL A POMMIE BASTARD
AND IM SUR THERE S LOADS ON HERE WOULD AGREE WITH ME
I never said I was unhelpful, Brown Starfish, Did I ? and I tthink your wrong in crashing in on someones post to slag someone else off.. it's ok to slag me on my posts , as I will surely endeavour (Try, for aussies) to do on yours..!!
hey likklespunk
next time your on your mummy
just think the reason your likkle branch
cant touch the sides
is b cause of my big
DIDGERYDOO
POM FU.CK -
The point of my post is not for you guys to B_llsh_t on I needed help and got it from someone that would help me. If you want to fight go some where else.
Thanks likkletree that helped alot.
Join .avi files, different video sample rates
By -mm- in forum EditingReplies: 22Last Post: 12th Oct 2014, 07:46 -
Sample Blu ray, m2ts, mts files
By pepegot1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 8th Jan 2011, 16:15 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 11:26 -
Viewing tests and sample files
By Movie-Maker in forum Newbie / General discussionsReplies: 5Last Post: 6th Sep 2008, 13:56 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15
