  1. Just want to ask anyone if a freeware exists that would allow me to compile all my MPEG-1 (VCDs) into one DVD-R. I think we all know that MyDVD does not provide that much free space when compiling them into one DVD-R. The best I've done with MyDVD was two MPEG1 discs. I appreciate any suggestions you all can provide.
  2. Member wulf109's Avatar
    Jul 2002
    Try SpruceUp for authoring,it supports mpeg audio and ac3. You shoudl be able to put 5 VCD/SVCD on a DVD-R. MyDVD only supports PCM audio and it as you point out consumes a lot of file space.
  3. With Spruceup being a demo only, i should still be able to author all the VCDs right? Not sure what the limitations are.
    Just to clarify on my steps, once I've authored all the VCDs in Spruceup, then I can just go to Nero to burn it? Thanks again.
