  1. Hi...
    I'm just beginning. Can i copy more than one file on a VCD. If i copy for example a two minutes file on a VCD, Am i done??
  2. what are you useing to burn the files. i use Nero5.5 yes you can. just drag and drop as many files as you want or till the cd is full. after that, then you'll learn to make opening pages and chapters(if you have more than 1 file). Thats when the real fun begins
  3. I use Nero too. I see what you mean. Thanks for your help and the fast response...
