  1. ive just started having major audio/video sync problems only in media player 9 after install winmpg convertor program. Ive uninstalled winmpg but the problem remains. the mpgs play fine in power dvd.
    I beleieve it may be a codec problem? this was probably asks a thousand times but cant locat the info. How to you change what codecs are used for playback of mpg files? Thanks for any help.
    Aug 2002
    England
    Hi
    Just accept that WMP 8 or 9 are both a pile of pooh.
    Use PowerDVD for all your files.
    It plays DivX and everything.
    Or try freeware like zoomplayer.
    They are all better than WMP.
    Fozzee
