Is a pack of 25 Datawrite 4.7g DVD+R (2.4x) discs for £11.59 a good price?
And do they work ok in the Sony DRU-500a?
These are from http://www.blankdiscshop.com
Best Regards
Barry
I've bought two packs of these disks from www.blankdiscshop.com/ so far and they work fine in my Ricoh MP5125A.
I haven't seen any cheaper in the UK. -
I got some of those discs (but in 10 pack) from www.bigpockets.co.uk and I had problem with them all the time. I burned movies that where close to the maximum size and they seem to skip and pause at the end of the movie on nearly all the discs. I then used a more expensive disk from www.medeainternational.com/infiniti/index.htm and these discs worked perfectly every time. It might have been just the discs I recived that had this problem and it was over a month ago so they might be better now.
4.7GB DVD+R Price increase
By hddvdrebel in forum MediaReplies: 4Last Post: 6th Apr 2012, 18:35 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Blue Ray disks command premium price in China
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2009, 13:57 -
DVD FAB 5 is it worth the price?
By rcguy1 in forum Newbie / General discussionsReplies: 17Last Post: 25th Nov 2008, 09:15 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24
