If my main purpose is to create svcds is there any point to capturing at 704x480? In a 50 minute capture at 29.97fps I lost about 150 frames, I'd like to reduce this but don't really want to sacrifice quality. My source is VHS, anybody have any pointers? Thanks in advance!
RiG
reducing the vert rez (480) will result in the biggest loss in quality, so i'd leave that alone. but, if you are capturing from VHS, 640x480 rez captures is more than adequate. in fact, 704x480 on VHS captures may be overkill...
<font size=-1>[ This Message was edited by: hitechjunkie on 2001-08-30 08:44:43 ]</font> -
Thanks for clearing that up for me, I tried capturing at 720x480 as I've seen recommended but it made a big green bar down the right side of the picture, almost as if the source couldn't fill that size so it just stuck garbage in there. Thanks again.
RiG
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 13:24 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
Standard XVID Frame Sizes
By adalect in forum Newbie / General discussionsReplies: 15Last Post: 16th Apr 2010, 01:11 -
Do I need to change AVI frame sizes before convertx to DVD
By johnharlin in forum Newbie / General discussionsReplies: 6Last Post: 18th Nov 2008, 20:58 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 23:53
