Donīt know if that is the right term, but resulting picture on VCD looks like an encrypted DVD (blocks) and sound is very "noisy" with some kind of "Morse-Code" in the background.
Source material are musicclips (mpg) from the internet. Some work, others show above artefacts. I usually work under Linux, but effect also takes place under Win using Tmpegenc and WinCDR.
My hardware is a JVC R2626 burner and a Matshita DVD drive.
The source mpg-file looks great, my bin-image looks great and also WinCDR gives me no error message. But the burnt VCD has the artefacts.
Anyone ever had the same troubles?
Thanx in advance
bg
Results 1 to 1 of 1
Artefacts when streaming a high frequency signal through S-VHS
By mamoltub in forum Video Streaming DownloadingReplies: 5Last Post: 24th Apr 2012, 09:46 -
Is it possible to Fix Bad Reception Artefacts with AviSynth??
By VideoFanatic in forum RestorationReplies: 6Last Post: 15th Nov 2011, 15:31 -
Need help removing some artefacts
By kotyczka in forum RestorationReplies: 28Last Post: 3rd Jun 2011, 12:17 -
Artefacts in recoverd MPG files from JVC DR-MH30
By PGottfried in forum ComputerReplies: 3Last Post: 31st Jan 2010, 21:10 -
Capturing from my DV camcorder: artefacts with straight lines (fuzzy)
By hydrocynus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 14th May 2007, 19:56
