I have downloaded the aspi adapter check.exe and it says that is it not working right. So I tried to install the updated one(4.71) the only one I could find on this site. It won't let me do an update and tells me that it is working fine. It isn't however, as I can't unlock the vob files for my first dvd rip to avi. I am using win xp witha 1.75 ghz processor and I have smart ripper, dvd2avi, chapterxtractor, tmpgenc, lsxmpeg encoder and a host of other programs including windvd installed. Have I corrupted this adapter in some way and if so how do I fix the problem, I have been searching the forum for a long time looking for an answer.
[img]Thank you all
Modartist[/img]
Modartist
Some are born to rule the world. to live their fantasies.
While most of us just dream,
of what we would like to be. -
had similar ....
First uninstall .....
then install 4.71 ..
then before trying to use - restart PC ... -
Ok , I am under the understanding that the only way to uninstall the aspi adapter is to delete the files in aspichk.exe that come up. I have done this two times and it still won't let me install the new 4.71 ones. Is there anyother way to do this I am not aware of ?
Thank you so much for you helpModartist
Try usig the forceaspi drivers and also if you cant rip the vob files are u playing the dvd on your pc first to unlock the drive and then you should be able to rip the vob files
I dunno...it might work -
Thank you so much, That did it, I had to play it first to unlock the files. I don't remember seeing anything on here about playing it first to unlock the files but that did the trick.
Forever in your debt
ModartistModartist
What usb wireless N adapter to get?
By neworldman in forum ComputerReplies: 2Last Post: 3rd Nov 2010, 09:49 -
YPrPb adapter
By BlackBumblebeezzz in forum Newbie / General discussionsReplies: 24Last Post: 19th Sep 2010, 15:11 -
Wireless Adapter
By Sakuya in forum ComputerReplies: 13Last Post: 21st Dec 2009, 23:40 -
IDE to Sata adapter....
By kenmo in forum ComputerReplies: 4Last Post: 2nd Apr 2008, 14:11 -
Problem with Toshiba AC adapter
By jyeh74 in forum Off topicReplies: 4Last Post: 14th Jan 2008, 11:37
