1) Most of the time when I use TMPEnc (80%) I get some kind of error in the encoding process regardless of what I use
I always get one of two errors
Read Error ocurred at address 0049EECD of Module 'TMPGEnc.exe' with 00D4AFF4
or
Illegal Floating Point Decimal Calculation
I will say though that I am d/ling stuff and surfing the net when I encode, however if you see my PC Specs you'll know the PC is strong enough to handle it...could that be the cause?
How can I solve this? I'm using TMPGEnc Plus Edition...
Here is my second problem. I have a Divx (approx 182 megs which turns into about 24 minutes long) in 640*480 and I'm trying to sample around to get to TMPEnc. One of the things i'm doing is encoding small parts at a time vs an entire movie on a Cd-RW and mess with the settings.
Obviously I'm new to video encoding (though not Pcs themselves..I build them in my spare time)
Yet whenever I try to encode in SVCD (480*480) and it works(read problem above) the file always comes out in 640*480...NOT 480*480.
Any way to solve this?
Thanks!
I found something interesting...
I decided to solve the 640*480 problem to go into Virtual Dub and extract the video and apply a filter tehre (since Virtual Dub NEVER crashes on me)
so I did it and changed it to 480*480
I encoded it agian (abiet only 3 minutes instead of the entire thing) and it CHANGED IT to 640*480 even though I specifically stated 480*480
Odd
DVD resolution is 720 x 480 ??
By siratfus in forum Video ConversionReplies: 6Last Post: 3rd Mar 2013, 10:47 -
Dazzle 720x 480 Frame Drop
By genericman in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Mar 2011, 11:37 -
DVP 5990 and 852 x 480 Resolution
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 6Last Post: 4th Nov 2009, 13:29 -
How to convert .vob file 702x480 to 720 x 480
By illpeeonu in forum Video ConversionReplies: 2Last Post: 23rd Jan 2009, 10:39 -
avi (640*480) to dvd (720*480) without black bars....how?
By Mauserman in forum ffmpegX general discussionReplies: 8Last Post: 10th Sep 2007, 13:25
