I have a AVI (Divx) movie and I want to be able to burn it to a DVD.
I can view the file on my pc, so I guess I have the Divx codec installed.
The file length is about 700mb.
I have converted it using the help that has been posted but I am not sure what bitrate to use. I did try a bit rate of over 5000 but the output file was larger than what could fit on a single 4.3G DVD.
I know there are bitrate calculators available, but any help would be appreciated.
thanks in advance.
Remember to let us know what program you are using. I use TMPGEnc to encode my files before burning. Takes most of the guesswork out of burning. If you know how to use a bitrate calculator, this site has one in the Tools section.
Hello. -
I dont think that there is any point in putting the bitrate any higher than it was before, since you cant make it any better.
Possible to burn a single 8gb file on a DL disc???
By moggsy in forum DVD & Blu-ray WritersReplies: 22Last Post: 11th Jan 2011, 20:09 -
burning Divx/AVI on data disc or stay with DVD VIDEO ?
By aznbladez in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2010, 08:40 -
dvd to a single avi file
By makapa in forum DVD RippingReplies: 1Last Post: 30th Oct 2008, 11:40 -
How to combine 2 avi's one above one below into a single file
By werx in forum EditingReplies: 2Last Post: 5th Oct 2007, 07:53 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
