  1. What's up
    i converted some ASF videos into MPEG with tmpg.
    Now i'm trying tu burn them (i'm using vcd easy) and with some of these i get the message that i need autopadding and that the video is WRONG FRAMERATE.
    I don't understend what's wrong and why some of these work and others no.
    Thanx in advance
    Apr 2002
    The State of Frustration
    What template in TMPGEnc are you using?
    Hello.
  3. i use the pal.
    Some of the movies that i'm trying to burn are converted from ASF to MPEG and other are already MPEG.
    And the message is always the same.
  4. Hi,
    I'm with the same problem, but using DVD Maestro. At compile time it gives a framerate error. I tried the DVD-PAL template and some variations of field and deinterlace settings, unsuccesfully (i've post two topics in this forum)
    Cinemacraft generates valid files for DVD maestro, but i'd prefer compress with TMPEG.
