  1. I'm hoping I can get some help here. I have burnt several family albums prior to this incident using the above software combination, however this time for some reason I have the following problem.
    The bin/cue file when loaded by Nero comes up as being over 4.6 Gigs in size, however the starting file (bin/cue) is only 500megs in size. And my hard drive is only 3 Gigs in size.
    I have attempted to cut some of the information from the VCD that PictureToTV is using to create the BIN/CUE file however even then the resulting bin/cue is only 60megs, however Nero still advises me that the size is still over 4.1Gigs. . . .
    Any assistance, or help would be greatly appreciated. This was supposed to be a digital copy of our wedding album for my wife for christmas, then for new years. . ..and now it appears perhaps her birthday for the end of the month. . ..argh!!!
    universe
    why not just use the burn option in picture to tv works for me every time
  3. That option is not available to me using the CD burner that I have.
  4. You may want to try updating your Nero. Earlier versions of Nero 5.5 has bugs with burning BIN/CUE's. The latest according to their website is 5.5.10.0.
    Regards,
    - Fruitee
  5. I just finished upgrading Nero to 5.5.10 and still get the same error message. .. .. is there any special codecs/drivers that I need. . . .that perhaps might have been deleted????
    Me = Frustrated To Heck
  6. i also use this combination pretty often ... did u try to re-install the picturetotv appln? else try to reinstall the nero again
    last resort: extract the bin/cue to mpeg1 with vcdgear, then use nero to burn, but then u lose the front menu interface
