Hi,
I am trying to capture and convert some videos that I have on my DV tapes to VCDs. I used Ulead DVD MovieFactory to do this. But the quality of the movies on the VCDs are very poor. Can anyone advise how I can achieve a better quality? Thanks.
edited your subject, please do NOT use "help me" subjects!/ Baldrick
You could try use TMPGenc instead. Copy the dv to your hd and convert with tmpgenc
www.vcdhelp.com/tmpgenc
and then add the tmpgenc mpg vcds in moviefactory and burn. If you are still not happy with the quality you could try SVCD, www.vcdhelp.com/tmpgencsvcd if your dvd player supports it.
Achieve the best possible audio quality.
By Robertiebert in forum Video ConversionReplies: 8Last Post: 23rd May 2011, 10:35 -
please advise me what should I do for good quality video streaming
By fx777 in forum Video Streaming DownloadingReplies: 5Last Post: 29th May 2009, 19:47 -
how to achieve max quality in fairuse wizard, x264 settings
By llmercll in forum Video ConversionReplies: 21Last Post: 17th Jan 2009, 09:17 -
How can one achieve MAXIMUM PSP video quality?
By The.Yield in forum Portable VideoReplies: 1Last Post: 14th Sep 2007, 01:01 -
DVD->MP4 conversion quality problems - Need your advise
By amir77a in forum DVD RippingReplies: 6Last Post: 1st Jun 2007, 03:27
