Hi,
I have attempted to put AVI onto a DVD-R using the lastest version of Nero with the dvd plugin. When i tried to play it i got the video but there was no sound at all. Tried it on my pc and on two standalone dvd players and got nothing but the video.
Any help would be greatly appreciated
Thanks in advance
Jamez
Suggest you load the AVI video into a sound editor like Gold Wave and see if you have audio on both channels. If not, you can Paste and Mix it on the lacking channel.
Hello. -
Jamez79,
At least you are getting that far...
I'm using an old STB PCI Tuner/Capture card and when I previewed the one minute scene, I could hear the sound. While I was capturing it, I could hear the sound, but when I played the AVI file back on windows media player, all I had was the video.
Since I haven't made sure everything is hooked up correctly, I'm not going to post about "how come" now, but I will later.
Good Luck
Never discourage anyone...who continually makes progress, no matter how slow.
Plato
Video/Sound Issue (h264/avi files)
By o2intake in forum Newbie / General discussionsReplies: 7Last Post: 13th Mar 2012, 10:48 -
Phillips DVP5990/F7 and .AVI - video is Ok, but no sound
By PaulGor in forum DVD & Blu-ray PlayersReplies: 10Last Post: 16th Apr 2010, 13:12 -
No video only sound in the beginning of the converted file from AVI to DVD
By lankafta in forum ffmpegX general discussionReplies: 1Last Post: 21st Jul 2009, 23:16 -
AVI Files only playing sound, not video
By Choochi in forum Newbie / General discussionsReplies: 4Last Post: 11th Jul 2008, 15:42 -
Extract sound from AVI video and convert to AC3
By blizzery in forum AudioReplies: 2Last Post: 25th Jul 2007, 15:06
