used dvd xcopy with pioneer105. play in pc dvd and car dvd but not in home dvd panasonic rv31 any help please
I have heard of ppl having problems playing certain media in that dvd player, so i think thats the problem
Best Regards
Barry -
You have Media problems, don't use again that media. Don't use the following with Pioneer:
Princo, Worldgate, Intenso and Bulpaq.
Use this media:
TDK(expensive but the best that you can have), Sentinel(cheap - writes only at 1x) and Infinity(cheap - writes at 2x).
I will try other media, if I have news i'll tell you. -
I forget to wask, what media did you used, so that I can put it in my black list?
Other people have had the same problem with DVDXCopy which now uses Nero burning engine... The discs aren't playable on some DVD players.
So it is NOT always the media..........
I suggest trying Stomp RecordNow Max if you are hgaving problems.
Unfortunately DVDXCopy doesn't let its users use just any burning engine,
so you may be out of luck in that respect. -
You can rip with DVDXCOPY, save the files to your hard drive, and burn with RecordNow (bypass nero).
But what I have found is is that many DVD players just don't like cheap media. I can play just about all the cheap media in my PC DVD-ROM, but to 100% avoid any pixelation while playing media on my DVD players, I have to burn to the more expensive media. To quote Jim Taylor (dvddemystified.com), "you get what you pay for".
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
Any Programs Have Better System than Long Play, Extended Play?
By johnharlin in forum Video ConversionReplies: 3Last Post: 10th Jul 2009, 20:04 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 21:23 -
how to play mp3's randomly in folder without play lists
By deejay.2001 in forum Software PlayingReplies: 4Last Post: 22nd Apr 2008, 14:27 -
Avid Lquid 7 menus..play chapter and play all
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 02:34
