  1. i keep getting incorrect perameter when i try to save avi with virtual dub,plleeeeeeeeze help
  2. Bravo , what exactly are u trying to do..what file are u converting or saving ...what settings are enabled (direct stream , full process , compression settings , etc. )
    I will try to help if i know ..just need more info.
  3. thanks i fugures it out i was trying to change avi but didn't get the correct settings.thanks anyway for trying peese
  4. need to learn how to type better.i figured it out.thanks anyway.
    peese
