Hi ..i a am trying to upgrade firmware 10 d to 10 f but it puts me in a loop. I try to upgrade and it tells me to restart my pc and i do and it tells me to restart my pc and this just keeps going on like that. It wont let me upgrade. I tryed it in safe mode with no luck. Sony support did not answer my email ..
So any help would be great. Thanx.
Ps using xp home ed.
There was a couple of post about this. Do you have any "non standard" IDE driver ? Did you run both times in safe mode ? Did you followed all instructions given by sony web site ?
I have (Standard IDE ATA/ATAPI controllers) drivers. And i followed the instructions ... change dma to pio ..and turned off my anti virus and firewall..
And all the upgrade lets me do is restart my pc and i did this a couple times in save mode.
Too bad sony wont write me ..i may have to call them. Thanx for the thought. -
I had the same thing. You must click on the dropdown box & "select" the Sony. Then it knows you are certain. Seems counterintuitive & downright stupid but it works.
Panasonic DMR-ES45VS, keep those discs a burnin' -
Nope ..didnt work. Still stuck in the reboot first mode. Thanx anyway.
Maybe i will uninstall all my burning programs and try that.
Thanx -
Nothing that was on this site helped ?
http://www.vcdhelp.com/forum/viewtopic.php?t=129453&highlight=
http://www.vcdhelp.com/forum/viewtopic.php?t=123337&highlight=
Lite-on DD-A100GX firmware upgrade?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Feb 2011, 04:45 -
GoVideo DVR4100 Firmware Upgrade
By csupan in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2009, 22:03 -
Samsung BD-P1500 firmware upgrade
By D-Generate in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Mar 2009, 07:50 -
DVDR-3380 Firmware upgrade
By Spideray in forum DVD RippingReplies: 2Last Post: 25th Jan 2009, 03:13 -
where to get original Sony DRu-820a DVD Firmware
By scustalow in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jun 2007, 12:00
