Currently I am capturing ATI-VCR2.0 and transcoding to MPEG at the rate of one capture a day. Unacetable as my sis also needs this computer.
I need something with an onboard encoder chip. I only have 350mhz of processor power. (PII with MMX)
I see some bad reivews on the Win TV PVR. What about the Dazzle DV bridge.
Just to give u an idea.
Their are about 20 tapes sitting here and anouther 40 in a box somewhere. Plus my 50 or so VHS tapes.
I can spend money.
<font size=-1>[ This Message was edited by: Greg12 on 2001-08-29 17:46:12 ]</font>
Results 1 to 9 of 9
bang for the buck, the research i've done says Dazzle DVC II is the best choice right now
well the Dazzle II is $399, The PVR is $240, I have been using the PVR now for 4 weeks, out of the box it sucked it was not until I got the SVCD, manual setting patches from the German Hamppuage web site that this baby started to cook.
Now for VCD it still unaceptable to me, But SVCD's look great on my 36in and my dad's 52in big screen.
If all you want to do is VCD, stay away from this one though.
For VCD I got one better than dazzle and half the price.
Creative Labs UBS Moviemaker, its $199 does VCD and MPEG2, it produces a very sharp and colorful VCD. But MPEG2 has to much lag for my taste.
Tried it out for a week returned it for the PVR because I wanted SVCD, not VCD.
With UBS no opening up computer either, pretty new device been out since last or may. Fry's just got them in 6 weeks ago. -
Oh by the way dazzle II $399, you can buy a VCD Stand-a-lone recorder player now for $399, works just like a VCR.
Look at the list this web site provides.
Can see samples at http://www.avdeal.com/demo -
thxkid Yes MPEG1 has a bit noise around objects in mpeg1
but I can sure you this is going to be fix.
Over all the WinTV-PVR drivers has gotting a lot better.
As for Creative Labs USB Moviemaker is junk pure junk.
<font size=-1>[ This Message was edited by: SHS on 2001-08-30 16:02:27 ]</font> -
I am most interested in VCD, but I also do work with SVCD.
I am getting a new laptop soon from my company. They don't care what I do with it as long as I don't open it. I am allowed to add external devices (video cards, cd burners).
Since the processor will be at least 200mhz faster than my desktop, maybe I should explore USB capture.
thxkid don't you know about my site SHS Unofficial WinTV-PVR http://shs-tv.m0ss.com/ SVCD is now build in PVR 1.4.19205 the SVCD you looking at is the one I pass to Hamppuage a long long time ago.
Anyway Greg12 you may as well count out SVCD with USB capture the bandwith on USB is to small for SVCD capture in tell USB 2.0 come out or build a Firewire ver.
I don't matter weather or not you get a Dazzle DVC II PCI or Hamppuage WinTV-PVR PCI your CPU usage will be very low. -
by the Dazzle2 to for $279.00 at http://www.bestbuy.com
<font size=-1>[ This Message was edited by: spiderman2k1 on 2001-08-30 20:41:25 ]</font>
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 03:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 11:38
