When i capture in vdub, my vt adjust goes from +0 to +50 and causes me to lose frames. If anyone knows how to fix this please let me know, id appreciate it.
Results 1 to 21 of 21
Virtualdub purposely drops the odd frame to keep the video and audio in sync, this is completely normal.
well that always causes me to drop frames. so in 4 mins it makes me drop 10-15 frames.
That is a bit excessive, I lose the odd 1 or 2 in 4-5 mins. Are they all lost in 1 burst or do you lose 1 at a time.
basically vt adjust shoots right to +9 then i drop a frame. then it goes to about +13 and another frame. etc etc etc
Are you using an onboard sound chip
Depending on your system, you will get some dropped frames simply because the clock on your video card and sound card are not perfectly syncronized.
VirtualDub will drop the occasional frame to maintain video and audio sync. This is a good thing (unless you want audio sync problems). It is also unavoidable unless you get another soundcard. -
Craig Tucker, I get the same problem , I have onboard sound and I lose lots frames with vdub...Lots. If i CAPTURE 200 FRAmes, i lose about 75. But I have it set up NOT to capture audio...it still does drops crazy frames. I dont think it has anything with sound card , cuz when i use AVI IO and anything else, I dont drop any frames at all.
I don't know how VirtualDub thinks it's correcting the sync, but I have found that it doesn't do a very good job. Even though I select "lock audio to video", the only way virtual dub captures are 100% in sync is if I don't drop one single frame the entire capture. If I drop 1 or 2 frames, it is slightly off but still watchable. Any more than 2 frames dropped, and it's like watching a Bruce Lee movie dubbed to english.
1 or 2 frames shouldnt make a differnece..I wonder if you could edit that in premier ? you know what I mean??? Just copy the frame before the one that got dropped and paste it in? I guess that would be a lot of work..nevermind .
It would be a lot of work, even if I knew where in the stream the frame was dropped (which I wouldn't).
1 frame out of sync equals 0.033 seconds (at 30fps), which is at the limits of perception. 2 frames is .067 seconds, which is noticable if you're paying close attention. Once you get up to 0.1 seconds off sync, it begins to get objectionable. -
Do not select lock audio to video, and try again.Originally Posted by Necromancer
dude, i figured out why i was losing frames in virtualdub....i guess the default capture is set at 15 frames per second... i changed it to 29.97 and now i dont lose anything. dunno if that hepls or not..
Did it fix the problemOriginally Posted by Necromancer
I'll be trying this myself too Craig, despite me thinking that 'do not select lock audio to video' sounds exactly the soloution to out of sync issues, right?Originally Posted by Craig Tucker
As you're in the UK too, what are your thoughts on dropping the frame rate from 25fps to 24.976fps to correct sound sync issues?
It's been kindly suggested to me by another forum user but I've yet to try it.
Will
www.milfordfc.com - maybe we should have a friendly, we both look as bad as each other
It did seem to work for me, but for various reasons I have not had the time to do a sure test.
VT isn't causing the problems, it's trying to make up for your lost frames. You're having a dropping frames issue. Try no sound/different card and lower resolutions (also different codecs prossibly) and see what happens.
Locking the audio to video will cause sync problems if your soundcard and video card clocks are not perfectly synchronized.Originally Posted by Silky31
Never tried it, I always capture at 25 fps, do not lock audio to video and my captures are perfectly synced every time.Originally Posted by Silky31
Wheres Milford
Right in the heart of footballing country my friend, ten miles from from one of the greatest teams ever to grace a football team.Originally Posted by Craig Tucker
Home to some of the most beautiful landscapes in the world.....Yorkshire (Leeds to be specific).
Will -
Bit of a trek from Swindon to Leeds :P
I was kiddingOriginally Posted by Craig Tucker
I'll try the 'don't lock audio to video' suggestion tonight and report back.
Thanks,
Will
adjust angles
By ecos in forum EditingReplies: 2Last Post: 31st Jan 2012, 18:00 -
Adjust audio level
By drgt in forum Newbie / General discussionsReplies: 7Last Post: 11th Aug 2011, 14:03 -
Adjust audio that is too high
By roglopes in forum AudioReplies: 11Last Post: 3rd Apr 2011, 09:26 -
How do I adjust the sound
By mmkk in forum Video ConversionReplies: 2Last Post: 28th Dec 2009, 14:52 -
adjust the volume
By volam in forum EditingReplies: 9Last Post: 1st Mar 2008, 20:19
