Hi now and then I get a horizontal scroll bar, its not there on all posts.
I tried to improve things in the settings changed 100% to 660 but it refuses to save the changes.
Most pages are ok, but for some reason like this pages there is a horizontal scroll bar.
800 X 600
it should look better now, in both explorer and netscape.
and if you type 100% under my preferences and press OK was does it says then? that you settings was changed?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
It said it "saved the changes", but if I go back and look they are not changed.
It was on 100% but since I had this problem I thought I would try 660, it never saved.
IE 5.5 and now IE6, see how it goes if you did something...
Thanks ! -
i've manually change the width to 100% for you....dont know why you cant change it.
does it look better now?
size problem with brrip
By krtsa91 in forum Blu-ray RippingReplies: 3Last Post: 21st Feb 2011, 00:21 -
web page translator and email full page translator
By juststarting in forum ComputerReplies: 3Last Post: 1st Feb 2010, 09:23 -
A good size of flash mp4 file on a page
By Cazz in forum Video Streaming DownloadingReplies: 5Last Post: 20th Dec 2009, 13:40 -
DVD size problem
By ranchhand in forum Video ConversionReplies: 10Last Post: 10th Sep 2007, 15:42 -
Estimated Size Problem
By NHLroyrocks in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2007, 01:17
