im new to the to the scene and need help(please)
i have two players the one im having trouble with is the medion 4310
it wont play vcds but when i checked compatability it should i think, also i tried region hack but nothing it only plays dvd my other recorder plays my vcd so no problem there, tried cd-r cdr/w
help would be appreciated!
MTM
Is it a standard-compliant vcd? (1150kbps, most importantly)
-Yar, matey!- -
how do i know if the hack works and does it help playing vcds
and its defenitly 1150kbps
thanks.MTM -
Ok, give me the following info:
1: What are you using to rip/encode/burn
2: What are the exact specifications for the vcd you are creating (like video bitrate, audio bitrate, interlaced/progressive, etc.)
3: What are you doing/using for the region hack
Oh, and if you rip it with smartripper, it will automatically remove the region code so you dont need the hack.-Yar, matey!- -
1. Smartripper> DVD2AVI, tmpgenc & nero , ive also used nero vision exspress
2. i use the wizard tmpgenc,
VCD PAL MPEG 1
vidio source-non interlace-16.9 display
movie info says 352-288 25fps/layer 244100 Hz stereo
vidio cbr 1150
audio 224
i wont need the hack then.
hope thats what you asked for, thanks for your timeMTM
dvd player wont play AVI or dvd video burned discs
By rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 14:01 -
downloaded video wont play in my dvd player
By KingRich70 in forum Newbie / General discussionsReplies: 17Last Post: 10th Jan 2011, 19:52 -
DVD Player wont play DTS 6Ch, can i change Audio?
By snadge in forum Newbie / General discussionsReplies: 31Last Post: 16th Jan 2008, 07:12 -
DVD-R burned using a DVD Recorder wont play on any other player
By weaseal4 in forum DVD RippingReplies: 4Last Post: 22nd Oct 2007, 12:37 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 16:26
