In the near future I intend on buying a ADVC-100 for converting old VHS tapes and home movies to play on my DVD player. What I plan to do is hook it up to my old laptop. The laptop itself has a docking bay which adds two PCI slots in which I can install a USB 2.0 card and firewire card. The system is or will be set up as follows:
Pentium 233 MMX
128 megs EDO DRAM
External (big) HD connected via USB 2.0 card
ADVC-100 connected via firewire card
My concern is that there will be some bottlenecks and/or problems with either with CPU speed, video chipset, memory, etc. making the additions pointless (and expensive). Any thoughts on this potential setup or suggestions for alternatives?
Since this isn't a capture device is the 400mhz based upon the device itself (I can't seem to find any reference on the Canopus site) or some other piece of the conversion?
The USB2 might be a concern. I can use my 266Mhz laptop to go from an analog to DV device, with the hard drive also on firewire. Don't know if you will get a bottle neck running across the PCI buss or not. In my situation, most everything is handled by the firewire card. CPU utillisation is about 50% using DVio for the transfer software. There is no preview with DVio! Most likely, you will not be able to have a preview with your setup either.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
Minimum System Requirements for capturing miniDV
By darkwhite in forum ComputerReplies: 19Last Post: 27th May 2012, 07:21 -
Minimum System requirements for Bluray ripping/burning?
By orbital517 in forum Blu-ray RippingReplies: 12Last Post: 28th Oct 2010, 11:32 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
Minimum system requirements to play 720p files?
By ukb007 in forum Newbie / General discussionsReplies: 11Last Post: 21st May 2008, 13:36
