I have a problem i can encode and record vcd's no problem and the all play back fine on my pc but when i use them in my yamaha dvd mostly all of them are stuttering beyond belief and audio cuts out. Some of my discs are fine but the last 4-5 i have burned all skip. I use nero to burn and i am currently using some white lable cdr 80mins. I never thought about the media being the problem but its the only possibility left as i have even burned them a 2x which is a slight improvement but still unplayable. I dont think its my dvd cos it plays back certain vcd's fine. Any suggestions on media and some confirmation if it is the media which is the problem would be nice.
Try different brands to see what works best for you. Different brand cd's work better on different players then others, and what works for me may or may not work for you. I've had good luck with namebrands (Maxell, Imation, etc) but bad luck with store brands (CompUSA, etc).
Princo~~~ Works on most DVD players that won't read anything else. It also cheap about 35-40 cents canadian which is about 22-27 cents us. Used over 5000 so far for vcds.
I find the best brands of CD-R for VCD are Verbatim and Fuji (The Ones Made by Taiyo Yuden, though).
Hope That Helps!!!
:P
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 17:31 -
burn vob into cdr
By pcb in forum Newbie / General discussionsReplies: 10Last Post: 18th Feb 2008, 13:28 -
VIDEO_TS on a CDR?
By kippard in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 06:20 -
.cdr file on a DVD+
By jamesmarcustucker in forum Video ConversionReplies: 1Last Post: 6th Sep 2007, 08:13 -
CDR TO DVD software please
By Lennoxtown in forum Authoring (VCD/SVCD)Replies: 5Last Post: 7th Aug 2007, 13:04
