WHen I put an MP3 as my background music why is it so much louder then my MPEGS? Do I have to change the bitrate or something?
No, just reduce to volume. The bitrate has to do with quality.
If you have a wav editor that can handle MP3's try cutting the volume by 3db to 6db. Cool Edit 2000 (free to try can do this). Look under amplification or amplitude for a way to cut the volume.
WinAmp can take MP3's and create wav files from MP3's for easier editing also.
5.1 wav or 6 mono wavs to 5.1 Ac3 conversion
By wturner in forum AudioReplies: 38Last Post: 24th Nov 2013, 09:26 -
Help - Split 6 Channels into separate WAVs
By stovk in forum AudioReplies: 6Last Post: 17th Dec 2011, 08:37 -
DTS-ES 6.1 to 7 mono WAVs
By Zetski210 in forum AudioReplies: 16Last Post: 28th Nov 2010, 02:13 -
How do I extract eac3 dd+ audio to mono wavs?
By yoda313 in forum AudioReplies: 15Last Post: 14th Feb 2009, 19:22 -
SixWAV2AC3 mono wavs files ENCODER
By arturjose in forum AudioReplies: 8Last Post: 19th Sep 2007, 01:45
