Hi guys. Hope everyone had a banging New years Eve. Got another question for those video Guru's out there. I have a 690.5 MB VCD that I downloaded from the internet. It appears that the entire movie is there but i only shows 21'33 of video before stopping. I previously had read elsewhere in the forums that DeMuxing and reMuxing would solve this. Once I did that I get a .m1v and a .pm2 file that both ast 1:09'14. Unfortunately my attempts at remuxing did not work. Below is what I got when remuxing in ffmpgX which was the identical output when attempting in MissingMpegTools. Can anyone tell me how I can fix this mpeg? I'm using Mac OS 10.2 if that makes any difference.
Last login: Wed Jan 1 15:17:03 on ttyp3
pbpaste | sh
Welcome to Darwin!
[My-Computer:~] MyUser% pbpaste | sh
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
INFO: [mplex] File /Movies/Bird/chunk-0.m1v looks like an MPEG Video stream.
INFO: [mplex] File /Movies/Bird/chunk-0.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Found 1 video streams 1 MPEG audio streams and 0 AC3 streams
INFO: [mplex] Selecting VCD output profile
INFO: [mplex] Scanning for header info: Video stream e0 (/Movies/Bird/chunk-0.m1v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 352
INFO: [mplex] Frame height : 240
INFO: [mplex] Aspect ratio : 1:1.1250 (4:3 NTSC for 720x480/352x240 images)
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 1150000 bits/sec
INFO: [mplex] Vbv buffer size : 40960 bytes
INFO: [mplex] CSPF : 1
INFO: [mplex] Scanning for header info: Audio stream c0 (/Movies/Bird/chunk-0.mp2)
INFO: [mplex] AUDIO STREAM:
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 44100 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 1410000
INFO: [mplex] target data-rate specified : 1411200
INFO: [mplex] Setting specified specified data rate: 1411200
INFO: [mplex] Sectors = 18 Video delay = 21600 Audio delay = 21600
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 47104 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Padding : sector=00000000
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=237600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 38788 frame=000059 sector=00000141
++ WARN: [mplex] Audio c0: buf= 2709 frame=000077 sector=00000025
++ WARN: [mplex] Padding : sector=00000000
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=597600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44799 frame=000165 sector=00000398
++ WARN: [mplex] Audio c0: buf= 4096 frame=000211 sector=00000068
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=957600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44803 frame=000271 sector=00000655
++ WARN: [mplex] Audio c0: buf= 4096 frame=000345 sector=00000111
++ WARN: [mplex] Stream c0: data will arrive too late sent(SCR)=1317600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 47104 frame=000376 sector=00000911
++ WARN: [mplex] Audio c0: buf= 1817 frame=000482 sector=00000155
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=1677600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44803 frame=000486 sector=00001167
++ WARN: [mplex] Audio c0: buf= 4096 frame=000620 sector=00000199
++ WARN: [mplex] Stream c0: data will arrive too late sent(SCR)=2037600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 47104 frame=000593 sector=00001422
++ WARN: [mplex] Audio c0: buf= 1817 frame=000760 sector=00000244
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=2397600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44803 frame=000700 sector=00001679
++ WARN: [mplex] Audio c0: buf= 4096 frame=000894 sector=00000287
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=2757600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44803 frame=000806 sector=00001935
++ WARN: [mplex] Audio c0: buf= 4096 frame=001031 sector=00000331
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3117600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44803 frame=000913 sector=00002192
++ WARN: [mplex] Audio c0: buf= 4096 frame=001165 sector=00000374
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3477600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44799 frame=001019 sector=00002448
++ WARN: [mplex] Audio c0: buf= 4096 frame=001302 sector=00000418
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3837600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44799 frame=001125 sector=00002704
++ WARN: [mplex] Audio c0: buf= 4096 frame=001439 sector=00000462
**ERROR: [mplex] Too many frame drops -exiting
(Super) VideoCD xml description created successfully as `/Movies/Bird/chunk-0.m1v.mpg.xml'
++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
++ WARN:
++ WARN: this is the UNSTABLE development branch!
++ WARN: use only if you know what you are doing
++ WARN: see http://www.hvrlab.org/~hvr/vcdimager/ for more information
++ WARN:
Processing complete!
Results 1 to 1 of 1
how to fix broken avi seeking?
By muffinman123 in forum Newbie / General discussionsReplies: 1Last Post: 9th Dec 2011, 18:40 -
Broken or not broken hard drive?
By romanstopme in forum ComputerReplies: 3Last Post: 17th Sep 2009, 13:04 -
How can i remove/fix some broken codecs?
By GangstaRap in forum Newbie / General discussionsReplies: 23Last Post: 23rd Feb 2008, 05:04 -
How to fix broken IFO?
By Hamilton in forum Authoring (DVD)Replies: 1Last Post: 24th Nov 2007, 04:16 -
how to fix broken mpg file?
By ecc in forum Video ConversionReplies: 4Last Post: 6th Oct 2007, 08:56
