  1. i got some new concerts on dvd for christmas
    i have ripped the dvds with dvd decryter and have all the files
    how can i make these files into wav's for my car?
  2. dvd2avi will make you a wave file. just load your vob file into it and hten go to audio and on dolby digtal click on decode and then save project.
  3. thanks for the help
    one more thing
    the dvd has like 22 tracks but there is not 22 vob files...how can i get it to where each track on my dvd is a wav. file. i just want to be able to play all the dvd tracks as cd tracks in my car
  4. well dvd2avi will make one great big wav file off of the dvd. i would just create my own tracks. i am sure the dvd is over 80 minutes if it has 22 tracks so you will have to edit it anyways. normally i would convert it to mp3 then use mp3 splitter. sure there is a program that you can do the same with a wave file. now just listen to the wav file and when each song stops split it then go onto the next and so on. so that way you would have 22 seperate songs. prob a easier way but this way works for me. plus i hardly ever do this.
  5. use DVD2AVI to extract the audio (you can either demux or decode, your choice). if you demux, then you can use BeSweet or Headac3he to convert the ac3 audio to wav, mp3, or whatever you want. BeSweet and Headac3he allow you to convert frame ranges, thus allowing to you cut the ac3 into its individual songs.
