I just completed extracting and re-encoding a 3 hour movie to SVCD. I now have 6 wonderful discs. Does anyone have a storage solution? Zip lock bags are not acceptable <smile>
Cordially
Ted Rosenberg -
The most I have seen are double type cases that hold 4 discs.
3 hours-->6 discsOriginally Posted by tedsla
sounds like overkill...is that VBR?? If not, you should try that in the future--you could probably get away with 4 discs for 3 hours w/good quality
what are you askin' me for...
I'm an idiot! -
Microcenter has 6 disc cases by Proline. Only place I have found them. Sometimes not available in the stores, but are on-line
SVP sell cases which holds 6 disks and sell for 0.69 GBP. Their shipping charges are quite reasonable as well. Their website address is http://www.blankdiscshop.co.uk/
Hope this helpsMantisgeek -
Don't even try to put them in a case. I put them in one of those book type holders that holds lots of CD's.
Yes, buy the 6 disc boxes from www.121cdr.co.uk I have quite a few of them, they are fine. Just watch out for the postage charges.
Best storage media for audio (long term storage)
By The Sumerian in forum AudioReplies: 6Last Post: 6th Mar 2010, 12:15 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29 -
CD Storage
By Nitro89 in forum Off topicReplies: 5Last Post: 1st Aug 2008, 11:13 -
Is optical media storage more stable than magnetic media storage?
By bevills1 in forum ComputerReplies: 24Last Post: 5th Apr 2008, 05:32
